teamspeak & ftp questions
27 Sep 2004
First question is concerning codecs.
I like to use teamspeak, and found a cool little teamspeak client for the mac, called teamspeex. There's a problem though, here's the error message its giving me:
[19:13:11] This channel uses an unsupported codec:
[19:13:11] GSM 16.4 Kbit
Any ideas? Would this codec be available to download? Is there any hope, that I might be able to use teamspeak on osx?
Second question:
I can quite easily access my ftp using safari, simply put ftp.domainname.com, enter my login details, and it gives me instant access to the ftp for my site, which is pretty good.
Although its listing all the files on the ftp, its saying that my ftp has "Zero disc space" available, and won't let me upload anything.
Any ideas?
Thanks in advance.
Probably easiest to just use a proper FTP client like Cyberduck really :) then get yourself a widget that you can drop files onto to upload them to a specific folder (like for when you want to upload an image to use on the forums).
