teamspeak help
connect, the server has given me isp number although I dont know what to do with it. there are lots of connection options I dont understand, do I just run ts in the background while css is on?
TS is just a background application, it doesn't have anthing to do with CS:S or any other game, so isn't tied down to anything in that game, you just talk over it.
Presuming you're running TeamSpeak 2, basically, all you're going to need is the IP.
Open up the program, select 'Connection' from the menu at the top, then 'Quick Connect'. Stick yourself a nickname in there, then type the IP address in the IP box.
Play around with your settings and test your microphone and talk key works correctly before connecting to a TS server, you people will be able to hear you, hopefully, straight away, instead of being confronted with either no sound at all from you, or a 200dB 'Hello!'.
