TeamSpeak server help
4 Feb 2007
Nuneaton, UK
Not sure if this should be here, mods move if it shouldnt.
Can anyone here help me get a teamspeak server to work.
Basically I can connect to it, but to do it i have to use a router style ip starting 192.###.##.#
If I try my main ip starting 81.###.###.## it doesnt work and it doesnt work for my friend either.
I have set up port forwarding on my router.
Anyone know why it doesnt work?
Thanks
Are you sure you have set up port forwarding correctly?
What error does it give your friend?
I think so, I used a guide on Portforward.com
but when i used my ip 81... it said out of range and would only work with my other 192... ip
You have three boxes on the forwarding page, the top one is for TCP and should be left blank, the second one is for UDP and should read 8767 and the bottom one should have your local IP address in it, ie the 192.***.***.***
Oh I give up, dont worry about it.
Just been told we well have a COD4 server with voice comms by monday anyway lol
Thanks for your help
