Just revived an old PC to use as a bit of a media center and network backup. Using a Raddy 7000 to output to the TV via S-Video. The image quality is generally very good (much better than I was expecting) but I have one annoying problem when playing movies. During slow pans the image seems to tear and stutter slightly. It's very noticeable if there are any vertical objects in the image against a plain background - you can really see them tear as it pans. It looks quite a lot like a game when you have v-sync turned off.
I'm using a Lite-On DVD-ROM drive and Power DVD software. I've had a mess with the plethora of options in the Catalyst Control Center and Power DVD software, but can't seem to cure it. The TV is just yer bog-standard 21" 4:3 box.
Any ideas on this? The basic system spec is...
Duron 1.2GHz / KT7A mobo
Radeon 7000 AGP
384MB PC133 RAM
Lite-ON DVD-ROM
ATA100 hard disks
WinXP Pro
Cheers
Radeon 7000 AGP
384MB PC133 RAM
Lite-ON DVD-ROM
ATA100 hard disks
WinXP Pro
Cheers
