** Tech Labs 7990 **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Available to pre order from today, we have the new OcUK Tech Labs 7990.
Featuring the excellent 7990 VGA card paired with the awesome new block from EK, the Tech Labs 7990 unlocks the real potential of the 7990.
This will be a very limited run and the blocks are expected to sell out very quickly.
OcUK Tech Lab H2O Custom HD 7990 6144MB GDDR5 @ £899.99 inc VAT
The New, Ultimate Solution
The OcUK Tech Lab H2O Custom HD 7990 combines the fastest Graphics Solution on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
This graphics card comes complete with a full cover EK VGA block from industry leading manufacturer EKWB, This is complimented with a functional backplate that adds a superb aesthetic as well as cooling.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
With more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 7900 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- HD 7990 is a dual GPU card
- Core Clock Speed: 925MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 2x384 bit / 5500MHz
- Load / Idle Board Power: <550W / <3W
- Power Connectors: 3x 8-pin required
- Display Outputs: DL-DVI-I, SL-DVI-D, HDMI and Mini DisplayPort x 2
- 2yr Warranty
* All graphics cards are blocked and fitted to order so please allow a lead time between 24 - 48 hours.
Only £899.99 inc VAT.
ORDER NOW
EK-FC7990 - Acetal+Nickel incl. Backplate @ £139.99 inc VAT
EK-FC7990 is a high performance full-cover water block engineered specifically for PowerColor/VTX3D/Club3D Radeon HD 7990 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools both GPUs, RAM as well as both VRMs (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7990 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel plated electrolytic copper while the top is made of quality POM acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure.
EK also encloses the EK-FC7990 Backplate made of high precision CNC milled aluminium with black anodized finish. This backplate directly cools the memory IC on the backside of the circuit board as well as serves as an aesthetic add-on.
Two-slot I/O bracket which replaces the original three-slot, in order to make installation of mutliple graphics cards easier, is also enclosed.
Up to four EK-FC7990 water blocks can be interconnected using EK-FC Terminal system or other methods of interconnectivity. This water block does not align with any other FC water block. This water block is not compatible with EK-FC Bridge CSQ series interconnect!
Enclosed:
- EK-FC7990 series water block
- EK-FC7990 Backplate - Black
- mounting mechanism with screw-in brass standoffs
- thermal pads
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance.
Made in Slovenia - Europe!
Only £139.99 inc VAT.
ORDER NOW
there should be two reference from AMD on future cards, One SKU water-cooled and one SKU thats air-cooled.
That way AMD can commission EK to make the Blocks :P
With various Water sensors under the block so that warrenty can be voided if required
