** TECH LABS 970 - FULL SIZE & MINI ITX AVAILABLE **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have finally been able to announce a full size 970 from Tech Labs using the performance solutions available for the 980.
Also in addition to this, we have ITX offerings with blocks from XSPC and EKWB
Huge range and you can be assured that the build is being carried out by watercooling specialists.
Excellent packages all round!
OcUK Tech Labs H2O Custom GeForce GTX 980 4096MB GDDR5 PCI-Express Graphics Card - EKWB Edition From £520.00 inc VAT
The OcUK Tech Lab H2O Custom GeForce GTX 980 combines the most overclockable single GPU card available with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
With a choice of the finest cooling solutions from EK Water Blocks, this card looks incredible no matter what finish you choose.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of IC Diamond is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The 980 operates at extremely low temperatures and has massive overclocking headroom out of the box, but the addition of a waterblock really allows the user to push the card to its limits easily and safely.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
From £520.00 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 980 4096MB GDDR5 PCI-Express Graphics Card - XSPC Edition @ £549.95 inc VAT
With a choice of the finest cooling solutions from XSPC, this card looks incredible no matter what finish you choose.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £549.95 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 980 4096MB GDDR5 PCI-Express Graphics Card - Aqua Computer Edition From £520.00 inc VAT
With a choice of the finest cooling solutions from Aqua Computer, this card looks incredible no matter what finish you choose.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card - XSPC Edition @ £439.99 inc VAT
The OcUK Tech Lab H2O Custom GeForce GTX 970 combines the best bang for buck single GPU card available with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
We use our exclusive 970 reference board and performance 980 blocks to gain max performance from your card.
With the finest cooling solution from XSPC, this card looks incredible no matter what finish you choose.
This card comes with a Waterblock and Backplate pre installed.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- Genuine NVIDIA 970 Cooler with Visualizer
- Genuine NVIDIA 980 PCB
- Samsung memory guaranteed
- Coil Whine reduction technology: We specify the capacitors/inductors to be enclosed in plastic containers as it helps reduce/eliminate coil whine
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1050MHz
- Core Boost Clock: 1178MHz (Upto 1268MHz Boost)
- Memory Size: 4096MB Samsung GDDR5
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
Only £439.99 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card - EKWB Edition From £419.99 inc VAT
With the finest cooling solution from EKWB, this card looks incredible no matter what finish you choose.
This card comes with a Waterblock pre installed and Backplate options
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
From £419.99 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card - Aqua Computer Edition From £419.99 inc VAT
With the finest cooling solution from Aqua Computer, this card looks incredible no matter what finish you choose.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 970 Mini ITX OC 4096MB GDDR5 PCI-Express Graphics Card - XSPC Edition @ £349.99 inc VAT
The OcUK Tech Lab H2O Custom GeForce GTX 970 combines the best single GPU gaming card available with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
The new NVIDIA GeForce GTX 970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 970 offers the most advanced performance in its class. 970 delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £349.99 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 970 Mini ITX OC 4096MB GDDR5 PCI-Express Graphics Card - EKWB Edition From £349.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
From £349.99 inc VAT.
ORDER NOW
