** TECH LABS PRESENTS - 980TI **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Its here
Confirmation from Block Vendors today that their Titan X blocks are fully compatible with the 980TI board
More versions will be available over the next few weeks when we see blocks from other vendors.
OcUK Tech Labs H2O Custom GeForce GTX 980 Ti 6144MB GDDR5 PCI-Express Graphics Card - EKWB Edition From £659.99 inc VAT
The OcUK Tech Lab H2O Custom GeForce GTX 980 Ti combines a fast single GPU gaming card with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
With a choice of the finest cooling solutions from EK Water Blocks, this card looks incredible no matter what finish you choose.
Never has a pre built watercooled card been such a complete package!
Ti. The most powerful two letters in the world of GPUs. When paired with our flagship gaming GPU–GeForce GTX 980–it gives you incredible new levels of performance and capabilities. GTX 980 Ti is accelerated by the groundbreaking NVIDIA Maxwell™ architecture to deliver an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
- Titan X PCB
- Titan X Cooler (Silver shroud)
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1000MHz
- Core Boost Clock: 1075MHz
- Memory Clock: 7010MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin & 1x 8-Pin
- 600W PSU Required
- 250W TDP
- Dimensions: L=282mm, W=110mm, H=43mm
- Warranty: 2yr
From £659.99 inc VAT.
ORDER NOW
Nice price on that as well. Very tempting
Ever thought is stepping in with an AIO for these things? They seem really popular and only evga seem to be doing them.
You just do it yourself with the nzxt g10 and any old aio cooler. It only costs around £50.
Yes but that thing looks awful. If I'm spending that much money on something I would want it to look a lot more £500-750 pounds worth.
I want something for my 970 but there is something different about the pcb on mine so non of them fit apart from that nzxt thing.
OcUK's own brand aio + g10 + 2 x SST-FQ121FW costed £60 exc vat and now its gone up (at the time it was cheaper than an AIO + G10 both on TWO). I spent ~£100 in total including a SST-FW92 PWM, 200mm Megaflow fan bundle, 2 x 200-140/120 fan shrouds & Gelid 4-pin VGA PWM adapter. Then I recylcled this:
http://www.tigerdirect.com/applicat...sPerPage=10&body=REVIEWS#CustomerReviewsBlock
My last one cost £19.99 for nzxt g10
£29.99 corsair h55
Ur going to be getting fans with either aio or full cover but there about £6 each.
Full cover blocks are around £79.99 but do offer better cooling
