- 11 Dec 2005
- Cheshire
Introducing a brand new watercooled system built from the ground up by our in house Tech Labs team. Featuring cutting edge components and a sophisticated cooling system, the "Titan 9450i Frostbite" is a cut above the norm. With dynamic styling, a ludicrous overclock and DX11 graphics, the "Titan 9450i Frostbite" is the definitive gaming system.
OcUK Tech Lab - "Titan 8450i Frostbite" Intel Core i5 4.80GHz Quad Core DDR3 System @ £939.95 inc VAT
The "Titan Frostbite" designed and engineered by the OcUK Tech Labs team from the ground up. Featuring an Intel Core i5 2500K 3.30GHz processor overclocked and guaranteed to a blistering 4.80GHz. With a full custom watercooling loop pre-installed the "Titan Frostbite" features quiet operation with ultra low temperatures allowing the processer to be overclocked to the highest standard. Harness the power of a multitude of graphics choice all complete with glittering DX11 graphics, providing a seamless computing experience.
Why You Should Buy This System
- True DX11 gaming performance available from a choice of compatible graphics cards
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- SATA 6GB/s and Intel Ethernet for next gen computing
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Corsair Carbide 500R - White
- Power Supply: PC Power & Cooling Silencer MK III 600w PSU - White
- CPU: Intel Core i5 2500K 3.30GHz @ 4.80GHz Sandybridge
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Custom Watercooling Loop
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: Choice of the latest DX11 Graphics cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Ultimate performance for the ultimate gamer. Custom watercooling keeps you cool in the heat of the moment and dyanamic white & black styling makes you stand out in the crowd.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £939.95 inc VAT.
ORDER NOW
And for those who already have the key system components but want the sweet watercooled setup and case. We have this:
OcUK Tech Lab - V8 Watercooled Case - Corsair Carbide 500R Midi Tower Case - White @ £259.99 inc VAT
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Mayhems Pastel - Ice White Coolant.
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
Corsair
Want even more outrageous cooling flexibility? Step up to the 500R. It adds a 200mm fan mounted on the side panel’s mesh screen for extra GPU cooling, a multi-channel fan controller, and removable and relocateable hard drive cages. The ability to move and remove hard drive cages not only improves airflow — it also allows you to install graphics cards of up to 452mm in length.
Support for USB 3.0 and 2.5” SSDs is built-in. Two USB 3.0 connectors are provided on the front panel and connect directly to motherboards with compatible USB 3.0 headers. Integrated SSD support lets you install 2.5” solid-state drives in any of the hard drive bays, without having to deal with adapters.
The beauty on the inside goes beyond the black-painted interior. Corsair’s innovative cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look. And since looks are an important part of any build, you’ll appreciate the ability to turn the front panel fan white LEDs on or off with the push of a button.
Corsair Carbide 500R Midi Tower Case - Black/White [CC9011013-WW]
- Side panel with mesh fan mount locations
- Dimensions: 20.5” x 8.1” x 20”
- Four 5.25” drive bays
- Six 3.5” hard drive bays with 2.5” compatibility
- Eight expansion slots
- Supports most 240mm dual radiators (15mm spacing)
- Six 120mm/140mm fan mounts
- Four 120mm fan mounts
- Front I/O Ports: 2 x USB3.0, 1 x FireWire, 2 x Audio
- Two-year warranty
OcUK Custom High End Watercooling Kit includes following items:
- EK Supreme HF CPU Waterblock - Copper Plexi
- XSPC X2O 200 Single Bay Reservoir Pump
- XSPC EX240 120mm Radiator - Black
- 6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shiny Silver Finish
- Mayhems Pastel - Ice White Coolant 1L
- XSPC 7/16" ID [16/11mm] High Flex Hose - Clear
- 2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £259.99 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Corsair
- Two-year warranty
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
ORDER NOW
