Technet Wallet
22 Oct 2004
Berkland
Hi Guys,
We have got a technet subsciption and the handy CD case they give you is getting a bit full, ie its about to explode with the amount of CDs in it.
Er, silly question, but what the hell should you actually keep in this case? Just bung all the cd's in there or is there some sort of logic to only keeping a particular amount of discs in it? :confused:
Cheers
I remember at my old work they sent us another zippy folder thingy eventually. It was just as the original one was about to explode too. I don't think anyone requested it either...
Or you could just throw away all the ones you'll never need. I remember about 75% of ours where useless to us, at least.
Ow, i think i understand it now after much mucking about.
1) Whack the index dvd in and then select shipment contents from the menu.
2) Select the subscription level, language pack, country, Type and Month and then select the 'All Discs' option.
It should then list what CD's/DVD's should be in the Technet Wallet.
All the others i have now filed away somewhere (just incase). :)
We've just moved over to the "Download" version of Technet Plus so thankfully we are no longer swimming in CD's (and later DVD's).
Basically however a lot of the disks you get each month replace existing disks - so you need to throw away a lot of your older ones.
Then it will all fit inside the wallet :)
