Technical interview and assessments
10 Aug 2003
London
Does anyone have any advice/tips on technical interviews and assessments? I have after being in the same job for over 14 years been out of practice, also very nervous and do badly at interviews and exams. I am kinda of bricking it over what would be asked in these interviews and assessments.
How and what can I do to help and prepare for technical interviews and assessments?. I am looking and going for system admin & IT support roles.
Thanks in advance
Very broadly speaking, technical interviews that I have attended (on both sides of the table) tend to come after the qualification stage - that is to say that you'll have already had some technical questions and successfully answered them.
In my experience there are a few stages - sifting questions at the telephone interview stage which are usually 2/3 very easy questions plus maybe a more challenging question to see how you answer. At a face-to-face you could expect to have some more relevant and challenging questions and these can be closed (testing your knowledge) or open (testing your approach). A technical interview tends to be a much more open forum where you're given a scenario and expected to talk through your solution and draw relevant diagrams etc etc.
In my most recent technical interviews, two were nearly identical in format - Split into two parts, I was asked to discuss an environment I had recently worked on (whiteboard diagram, design goals, challenges, outcome etc) and then basically design a technical solution to xyz problem.
The goal is to make sure that you know your stuff and that you have the sort of approach to the sort of things you'll come up against in the role to succeed. This obviously varies from role to role - design/project-focussed roles will demand very different skills to reactionary support roles.
To prepare, you need to be able to talk confidently about all of the common elements of everything you've listed in your CV, especially where it overlaps with the things mentioned in the job spec. Don't think that because you're interviewing for a Windows role that you won't get asked an in-depth question about Unix if you've put it down on your CV. The interviewer might well have decades of Unix experience, you've no way of knowing.
To prepare for any open questions, try to think through how you'd approach a greenfield deployment of whatever technology or how you'd approach coming in blind to a new environment that's undergoing a major issue. You don't necessarily need to know anything at all about the technology here (though it helps...) but basic things like asking for the requirements or documentation, any plans for expansion or if changes have been made recently etc etc.
Some technical questions are there just to boost the ego of the interviewer. Don't sweat those questions, they're probably beyond the reach of most candidates anyway. Try not to let them upset your thought process for the rest of the interview :)
Good luck!
I don't know how much this will help it really depends what job you do and what you're going for.
Always know your current job. If when asked you can't answer tecnhical questions on your current role how can I have faith you will master your new role. I have seen a number of otherwise good candidates flounder when asked questions about their current role which undermines their technical credibility. Mostly this is a matter of mental preparedness rather than revising because I assume you are competent at your current job.
I would echo that, not just for technical but for interviewing in general.
In terms of assessments, my recommendation would be to consider that you will invariably be given a shorter timeframe to complete it in an assessment than you would in reality so keep that in mind to avoid going down any rabbit holes that may not be that important relative to the overall scenario. Chances are they will be as interested to see how you approach a problem (Strategy) as physically what you do to tackle it (Tactics). If you don't have time to write/discuss everything you want to say try to summarise this e.g. if you believe that the solution lies in doing investigation XYZ but you don't have time to complete that investigation, make sure you at least state that is how you would tackle it.
Absolutely this. Could not agree more, especially the more senior (technical seniority rather than management) you are. You should be able to talk ad infinitum about every facet of your environment. The hows and whys of every foible, every shred of technical debt and so on.
Any candidate that can do that is making a shortlist unless they've made a spectacular hash of the rest of the interview process.
I was notified today that I have been short-listed for a job and have an interview and a technical assessment on monday eeek.. damn very short notice. So daunting and nervous already, can't even imagine how much more nervous I will be feeling on monday!!!.
