teeth whitening.
19 Jul 2006
Anyone know if any of the claimed teeth whitening toothpaste works, just im starting to get minging teeth, to much coffee i think. dont want them to be killroy silk white but a bit whiter then they are?
From what i have heard whitening toothpastes don't really work. They use abrasives to remove surface stains and polish teeth but they dont remove the discolouration of the dentin inside the teeth.
If you want them to be really white go to a dentist and get them bleached properly.
Um yeah. pearl drops can help polish the crap off them. My dentist recommended it so I use it about once a week, just on my front teeth and it does bring them up a bit cleaner. It won't actually whiten your actual teeth but it can clean them up better than normal toothpaste.
There are some mild paroxide teeth whitening kits, That do the job, My Ex used one and it worked great, but i don't remember the name of it. I'll ask her and post here tonight.
yeah getting it done properly via the dentist is at least a few hundred £250ish i think. And you have to get them whitened every few months or so i believe
Drinking no coffee/tea during the day and using pearl drops has helped mine a lot, it's slow but it is making a noticable difference.
and at the same time removing all your enamel.
It might just be toothpaste but there medicines all the same, and have side effects. Best getting advice of your dentist on what's available.
