OK
Since I don't have a BT line in my new flat. It has to be telewest. I am temtped with their 2 for £20 offer where you get 2mbit connection and digital TV starter package.
1) For the installation, do you need a TV or a computer there? Cos in a empty flat theres neither. (although a pc might be avaliable)
2) Is there just one box combining TV and modem?
3) Sky needs a phone line which i've mentioned above I don't have, does Telewest need on as well for activation or anything else.
4) Are there any caps what so ever on the 2mbit line? Is anything blocked or throttled like p2p or newsgroups? Any problems with usages upto 50gb per month or more?
5) Will the installers put the box where you want it? and will they route the cable properly? The sky installers did this?
6) Is there anything else I should know about the serivice and the installation procedure.
Thanks a lot
sid
Thanks a lot
sid
