Tell Me About 306 GTi-6's
7 Nov 2002
Snorbans, UK
Evening,
I've been thinking about 306 GTi-6's for a while, and yes, before you ask, I know the Xsara VTS is the same car etc etc, But I'd like some info about the 306 please?
How much would I be looking at for a reasonable one without starship milage? I don't mind 100k+.
Any things to look for especially?
And what kind of equipment levels do they come with?
TIA :)
Chap I play footie with has one. Bought it new in '98 and now has over 140k on the clock and has been pretty reliable. It does like a drink though, he averages 23-24mpg and drives it pretty carefully.
You sure about that mate? Thats pretty terrible mpg, infact I think my friends TI does better than that.
I've got one. It's a great car. They do a Rallye version to but that doesnt have air con, electric windows etc, though it is a little lighter.
Generally 2nd hand ones will have under 100k on I would have thought. I brought my Phase3 99 plate last year with 55k on the clock for £3000. I did get it slightly cheaper than usual though as I brought it off my brother and have always sold him bikes cheap in the past. I would still say you should be able to pick up a decent one with under 100k on it for £2500ish maybe. All depends on what phase you want. You will find that a lot of the older phase models have had bits changed so they look like a later phase model anyway by now.
As for reliability. The cambelt as mentioned should be changed every 30k regardless of what Peugeot say. Its a car that is hard not to put your foot down in every now and then as once you have done it once it just screams at you to do it more :D Fuel economy wise, there is definately something up with the one above. On a run I can average 35-37mpg and if I drive sensibly about town I would say I'm between 25-30mpg still. When I say sensibly I mean not having a traffic light grand prix at every set of lights. Best I have gotten out of one tank is 440miles until the light comes on, though most seem to get about 350 on the 306 site. I usually hit around the 400mark though personally. One thing to look out for is where the fuel hoses join upto the plastic 90degree elbow joints under the bonnet on the RH side of the car as you sit in it. The crimps can come loose sometimes. When I was playing around i knocked a hose and fuel squirted out!! so I have put cable ties on these connections too now and the problem is solved.
One thing is I did notice my economy got slightly better when I fitted a K&N filter (induction kit one) but I have stuffed it into the original airbox to prevent heat soak, Blueflame exhaust system (cat back) with a de-cat too. That said it may be because when I fitted this I also fitted a new Lamda sensor into the de-cat and maybe the older one was on its way out.
The only other reliability thing I can gripe about is the electrics. It is only in winter though when it is cold I get any issues for some reason. Like a digit on my ODO doesnt show up until the temp in the car rises a little. Sometimes the central locking plays up too for some bizarre reason that I cannot figure out, though tempting fate here as of yet it has been fine this year so far.
Performance wise, well I love it. 167hp standard (dunno what mine will be now, maybe 172hp the mods i have added wont have added much power though it does pull harder now) and the handling is just amazing, especially with the passive steering effect. Like the 205 gti they suffer from lift off over steer but I find you do really have to provoke it to do this and as I drive quite smoothly have only ever done it once in 15000miles when i really tightened a turn around a roundabout once, though I didnt lift off I stayed neutral it still broke away. Its easy to recover though (well mine was) just accelerated and straightened the wheel a small amount only and it came back in line. It goes well, 0-60 in 7.2 and stops well though that is another thing I have changed and put Tarox sport disks and Tarox sport pads on the front and now the brakes are pure evil! Can never have to good a brakes though.
I'm not sure what you drive now but you may find eveything in a gti-6 feels quite heavy. The steering is quite heavy even though it has power steering but it also gives a lot of feel which is great. The clutch is also rather heavy too. Sometimes this is due to the clutch cable which is routed near the manifold and the auto tensioner mech dries up. Changing the clutch cable can do wonders, though on *** gti-6 is a pain of a job as the air-con tubes are right in the way so be prepared to skin knuckles if you ever change it yourself (which I have done)
It really is a nice car to drive. I love the mods I have done. The exhaust and filter give it an amazing engine note on hard acceleration but when driving normally you cant really tell that they are there (bar at 3000rpm when the exhaust has a natural growl from inside the car) It is kinda sleeperish too as it doesnt look any different than a 306 HDI so people dont expect a 306 to go like a gti-6 does :D Just make sure you have decent tyres fitted so you can exploit the wonderful handling that this car has!
Gee I wrote a lot for this early in the morning!
Was just going to say with regards to the post above mine is China Blue :D
There are other colours available:
Nile Blue
Moonstone
Diablo Red (think that is right)
Blaze (kinda yellow)
Astor (dark grey)
Black
Think the Rallyes also come in White and Red which I don't think the gti-6 does.
Well err I think Gixers has pretty much covered eveything :p
But you can get GTi6's in Cherry and White as well ;) Oh and Silver & Sigma Blue (Phase 1/2's). I wouldn't worry too much about the colour though, more so the condition.
I bought my W-reg in Sept 04 with 33k on the clock. 2.5 years on and the clock reading just over 50k I've not had a single problem with mine :) Never let me down or failed to start. I've had the cambelt, exhaust and brakes changed in that time but that's all required work. I do have a few niggles I'm going to sort out mind.
As long as you get a well looked after one which HASN'T had the cambelt snapped in the past (look out for the head tapping) then it should be sound and plenty of fun :D
On the fuel side of things I really need to get my lambda changed. I get 250 miles purely around town or 320 mixed :o
I'm not massively bothered about fuel consumtion, 25mpg+ is fine with me :)
So how much would I be looking to pay for a decent one? Is it worth paying a bit more for a newer one?
TripleT - what are servicing costs like? I'd be doing all the work myself.
Here is my old GTI-6. Great car I had it from 6 months old and kept it for 3 years, I think I sold it with 80k on the clock.
As said, people watch out for the cambelt and water pump, I stuck to the Peugeot service intervals without issues, however there are reports of cambelts popping before the service due time.
I fitted a Peugeot Rally airfilter and that did make it pull a little better.
Once out of Warrenty I bought all my parts from Eurocar parts.
They are great cars, and deffo great value for money. Another note is that the airbag sensors under the seats can sometimes come apart giving a warning light. The Peugeot fix is to solder the connectors together. I never had an issue, but if you do easy just to DIY it.
Heres a pic for reference:
Servicing if you're doing it yourself should be no more than any normal car as it's all just standard stuff. Parts aren't expensive and they're easier enough to work on (saying that I don't touch mine as I don't trust myself :p). The main thing is the cambelt every 35k. If there's no proof that it's been done then do it ASAP. You'll be looking at around £350 for the cambelt, tensioner, roller and water pump (that parts and labour).
You could get a sub 100k decent phase2 for £2500 but prices do very wildly. I dunno how much you have to spend so it's a bit differcult. Rallyes which are 99 T's (normally) tend to be a mixture of Phase 2 & 3's (lights, fogs, boot lid, bump strips changes) and are around £3300. V/W/X Phaes 3's start at £3500 - £4500. But it all depends on mileage and condition really.
I'd obviously say try and get an average mileage Phase3 as there are a lot of dogs out there sadly but again it just depends on your budget. Best just picking a budget and keeping an eye on the members for sale forum for a well looked after one imo :)
