OK so what's the theory about cooling? - like, should I be sucking in the front, through the case, and exhaust out the back? Or what?
The fans on my system are driving me mad as they are really noisy and run at full chat
So, I know I can get a funky cpu cooler and reduce that noise. But in order to also reduce noise I'm thinking of replacing the 120mm rear fan in my case, & lowering fan speed.
My case has no fan at the front? even though there seems to be slots in the case (an old chieftec case). It has some weird black thing there, (on the interior), that does nothing. It seems to be about 100mm tall. I wonder if I could take it off and stick a fan there?
front:
Here's a pic of the rear case fan. That fan sucks from inside the case and blows out. And how can I lower the fan speeds? Tried speedfan but wasn't really happy with it to tell the truth. Also it only worked on my cpu fan I couldn't get it to affect the case fan? Can an aftermarket controller work or does it depend on the motherboard (mine is unfortunately a rather old Asus K8V SE).
thanks for any info to a newbie
Chris
front:
Chris
Might be a simple case of some compressed air or a new PSU
