Telnet
12 Sep 2003
Newcastle, UK
Hi all
I've been using Telnet to access my Router and extra settings, but stupidly just closed the window. Now when I try and reconnect it says that I'm still connected and terminates the telnet window.
Is there anyway I can reconnect, or simply just kick me out?
Thanks. :o
Once you turn it off you could wrap it in rubber and bounce it around, just to make sure. But the turning off and on again should suffice.
