Hi all , can anyone tell me the max temp i should be allowing when overclocking a SD 4000 @ present i am around 41 degrees under prime and at 1.61 volts , are these ok @2.9 Gig and dare i go any more
Hi , it is stable at 2.9gig at 1.63 volts and under load temp is around 39 - 41 degrees if i lower it to 1,6 volts even it fails under prime so i will try to keep it the same for a bit but do you think that is my limit , only i read people at 1.7 volts , or is that a bit too much ??
