Temp AppData filling up with Compositor YUV files
3 Jan 2018
Brighton
Hey, so I recently had an issue of 0 disk space which I managed to narrow down to a whole heap of YUV files in my Temp directory using TreeSize. I cleared them out and did some digging and found out that Nvidia ShadowPlay (or whatever the recording software is for Nvidia) uses the Temp directory for recordings and the YUVs.
I cleared them out but I'm still getting these YUV files filling up my Temp. I've currently got 32GB to delete.
I've always had nvidia's overlay, recording etc disabled as I never use it, I use SteelSeries Moments for gameplay recording which has also been disabled for some time now.
Is there anything else I can look at that may be filling up my Temp again?
Have you checked to make sure that a driver update hasn't re-enabled Shadowplay?
I did check previously, but I have since updated to the Nvidia App (maybe a mistake, let's see) and realised that has turned it back on... I've turned it off again and I'll see what happens.
