Temp check & may a pos overclock
4 Feb 2009
Birmingham
Im guessing these temps are ok but after running prime95 for the last 10hours i did think it would have pushed the CPU a bit harder & may be the temps go higher. So are they ok or still a bit low for after running prime for so long? or is it reporting wrong temps for some reason?
my idle temps are around 19c
If the temps are ok & you dont think the sensor is messed up an reporting wrong, how far do you think I overclock the cpu?
I was looking in to using AMD overdrive as im new to overclocking but iv been hearing good & bad things about it. So will it do a ok job if i use it to autoclock the cpu?
Spec:
phenom II 720
titan fenrir evo
