Temp check..!!
26 Mar 2007
Nottinghamshire
Quick check from those in the know would be good :D
Cheers
as a general rule (onc you have done what the above have said) anything below 60 degrees at full load is acceptable and should be undamaging (although a bit high)
If you get roughly the same temps as above when doing both cores then its perfectly fine, but cooler is always better :D:D
Surely thats dependant on the chip in question?
