Temp Check
29 May 2005
Hertfordshire
Got i7 930 @ stock using h50 with 1 akasa viper fan pulling air into case through radiator i wondered if these temps are acceptable had rig coming up year now.
Done 6 runs of Intel Burn Test on maximum setting the max temp it hit was 74°C my room ambient is 24°C.
Acceptable yes but not brilliant for a stock rig. My 920 rig @ 4Ghz 1.325v with TRUE in push pull with orange silent Nexus fans tops out at 77C in 30C ambient with IBT.
Ok cheers problem is that reading is by changing my ram back down to 1066mhz when i enable xmp in bios for my ram CPU temperature goes up to 47°C.
My motherboard is Asus P6X58D-E and ram Patriot Viper 6gb 1600mhz just want to know if anyway of keeping CPU temp down but ram running at 1600mhz.
