temp concerns
2 Mar 2007
my tempreture at idle is around 46c to 50c. Im using coretemp and its giving me these results when i use my pc probe it goes above the 50 marker. not sure what it could be recently attached the scythe ninja to my AMD fx62 cpu. if anyone could just point me to the right direction i would be greatfull.
ive checked the hs more then 4 times havent seen a problem with it.
heres a screengrab of coretemp. this is at idle by the way.
Set a credit card on it and see if there's a gap.
Tho I don't know if AMD chips suffer from concave IHS's like Intels do.
ok just tested it with a card and it looked straight. now after putting everything together my temps are 60c+. i think i might have put the hs on wrong or somthing this time round. is there anything else i need to check whilst im down there?
P.s there are some deep scratches on the surface of my cpu could that be causing the high temps?
