Hey,
I'm running x2 980Ti's in SLI with an XSPC water block on both in series.
When my cards are at idle there is a 4-5 degree difference between the two cards, the 2nd one of the two being the hotter one (obviously).
Under load however the temperature shoots up on my 2nd card to around 70-80 degrees, the 1st GPU sits at around 45-50 degrees max temp.
I'm thinking that it's something to do with the 2nd water block not making proper contact with the card, or that the thermal paste/pads need to be replaced.
What do you guys and girls think? Some other input would help!
