I've just built a system using a Asus barebones AE-1 and a sempron 2800+ cpu. It all works fine. The bios reports the temp at 40c, and Asus probe reports a similar result. however the person this was built for has installed a stupid bit of software called PC (forgot this part) 2006, which is reporting the CPu temp at 200C. They are insisting its a problem and they had a similar problem before which a bios update fixed. I know its complete rubbish. is it the software misconfigured, or just crap software?
