Lan said:as ok as the prog is temps aint worth $29, lol
You can add an offset to the readings. Core temp - norm. reported CPU temp = offset. Simple.Lan said:i think its probs going to have to be a temp probe i dont want motheboard readings because there not correct, wel they certainly arent what core temp gives me
dint think on thtA.N.Other said:You can add an offset to the readings. Core temp - norm. reported CPU temp = offset. Simple.
