Temp Monitor?
18 Oct 2002
North Wales
Anybody know a good one?
Speedfan causes a few issues on my system (stuttering mainly), and Systool I can't get to detect any temperatures for my board (K8NXP-9)
Anyone know of any others that work well? MBM is still out of development is it not?
Also, the ability to also read the temperatures from my X800 would be great too.
Download a copy of Everest. That monitors temperatures.
Scottland said:
Thats seems to work fine, except I can't get it to minimize to tray?
Also, how do I use the OSD features?
That's the problem I guess, you can't minimize it to the tray. OSD features? Do you mean how to use the features within Everest?
I've managed it now, I have to have the "i" system tray icon enabled.
When I'm changing the tray icon settings for temp monitoring etc, there's an option next to it for OSD. I presume there is a way for it to overlay temperatures etc on the screen, when you're in a game for instance?
ATI Tray Tools can do this with a hotkey, I presume this works in a similar fashion?
It's pomising so far, thanks for the recommendation.
Edit: Think I've sussed it now, the OSD is just on or off, doesn't look like you can control it with a hotkey.
Ah I see... I don't think you can make Everest show the temperatures whilst in a game?
I've only just worked it out how to hide the main screen, you have to click the icon and click "Hide Main Window"... thanks for letting me know. :)
Just enable the OSD and make sure in the preferences under Harware Monitoring that its always on top. It should show up in games that way.
OK, thanks! Should've worked it out. :)
