Temp monitoring on sli setup
Caporegime
14 Dec 2005
armoy, n. ireland
Im currently running a single gtx 275, got a second card coming next week for sli, at the minute i use msi afterburner for measuring card core temp, pcb temp and fps, the second card im waiting on is an identical xfx 640mhz core clocked model to the one i have, how can i keep an eye on the temp of both cards or will afterburner, gpuz do this, my last use of sli was with 8800gts 640's a few years ago so thanks for any advice.:)
I have a CF setup but SLI *should* be the same
Afterburner picks up and reports temps cores shaders etc as well as fan speed and usage for both cards and reports to my G15 LCD display
GPUz will record the details of two cards but you need two instances of the program running
Thanks, will afterburner display temps etc on screen for both cards, i have a G15 keyboard, but unfortunately the lcd display is knackered.
Yep
