OK thanks for the replies.
I keep hearing of driver signing and people turning it off.
How do i do it and are there any disadvantages?
Now when i was on XP, Everest gave significantly lower temps. Is it different in Vista?
Edit
Installed Everest and it says that my temps are 19 & 21 deg for my E2140 overclocked to 3ghz, sorry but i don't believe that one bit as in XP, tat reported betweent 33-36 on both cores (33 being the lowest i had).
So it looks like coretemp is my only answer if someone could explain what driver signing is about.
i mean do i disable it while i install the program or disable it permenantley?
