Temp Spikes
30 Mar 2007
I have a 6700k running @ 4.6 GHz on a custom water loop, Vcore 1.32. Running various stress tests the temperature hover between 55°C and 65°C for the most part.
Some times on load changes at the beginning and during stress testing the temp will spike in to the high 70's but it's so brief that it doesn't always get logged on some of the monitoring I have running. It usually only see it when looking at the min/max on HWiNFO64.
Is this normal? Is it some thing to be concerned about? I have pushed the chip a bit harder on higher vcore but the spikes hit 90's then so not risked it until I know more.
Any advice would be much appreciated.
Thanks
Mines exactly the same, custom loop, identical OC, the main CPU temp is the most spikey (mine doesnt spike to high 70's but will spike from say 50-60something) but the core temps usually start to settle on load tests... I think its normal, maybe the CPU casing is just a bit ****... Your 4 core temps are less spikey right?
