Temperamental No Signal.
1 Aug 2011
Hey guys,
I use my LG 32" inch TV as my computer monitor and use an HDMI cable with it. However I have a temperamental problem that doesn't seem to go away. Basically unless I turn on the PC and then immediately turn on the the HDMI channel that is set to the PC it'll be happy connect. However say I would turn on the PC then perhaps watch some TV on another channel or turn the TV off and come back later. To find the signal is lost. I then have to fix the problem by manually restarting the computer.
It's probably going into sleep or hibernate... or turning off the monitor/tv itself.
Go into control pane, power settings. Set it to high performance. Providing your using Windows 7.
