temperature check plz
12 Jun 2007
Ireland
using air antec 900 ram voltage 2.0 northbridge 1.45
temperatures : cpu 19.5c/67f ,motherboard 25c/77f , nb 42c/107.5 f , sb 30.5/86.5 f is everything normal ?
pc is on about 10 min
Looks fine to me. What CPU heatsink are you using? In fact, what CPU and mobo are you using?
The CPU is so cold that unless it's a specialty low voltage model or unless you live in a meat locker, I think the reading might be inaccurate.
asus maximus formula, case antec 900 , cpu q6600 g0 , cpu cooler zalman 9700
i took the reading from bios so im not sure how accurate they are
