- 24 Aug 2007
Hey
Just finished cleaning out my watercooled rig and wanted to check if the temps are about right
My CPU is running at 4.5Ghz and using Prime95 it hits 52 degrees. Sits around 20 degrees idle. Using Furmark, my GPU(s) are hitting around 48-50 degrees (idling around 28)
This is the fans set to performance using NZXT Cam software on my new GridV2 (it's pretty damn quiet!)
Can't get my CPU stable any quicker - but i wouldn't say i'm exactly "8Pack" at overclocking, but i assume the 4960X is still decent enough for gaming
Oh, best say what Rads i'm running!
Koolance HX-480HL 480mm
Alphacool Monsta 360mm (80mm thick)
Laing D5 Pump
XSPC 295X2 full block
Supremacy Evo Block
SP120 quiets all around except the front intake which are SP120 Performance editions (due to the obstructive HDD bays)
Many thanks
Laing D5 Pump
Supremacy Evo Block
Many thanks
