is there a simple way to over-ride the temperature sensor, so the fan runs at 100% all the time? they use 3-pin connectors so can't be controlled through motherboard as far as im aware. what happens if you simple cut off the temperature sensor?
Possibly speedfan will be able to do this by linking that fan into a table tied against the gpu temp.
