Hi there,
I have nearly had my rig from Overclockers a year. I upgraded the fan around Christmas to an Arctic Cooling Freezer 7 Pro rev2.0. I have never done this before, but it seemed to go okay. I use Speedfan to monitor temps, and I noticed it was colder upon boot, around 36c. But, when I have a few tabs open in Chrome for example, it soars past 50, regularly reaching 56c.
To me, this isn't safe. I have attached a photo to kindly ask if I have fitted it the wrong way round. http://postimg.org/image/6mxnkwvjf/
My case is the Coolermaster K380: http://www.coolermaster.com/case/mid-tower/k380/
I was going to add another fan to the back, to remove air, and I think this would help. I currently have a chassis fan that runs auto on a low level, and this cpu fan. My powersupply also has one, pulling air in I believe
So, two questions really: Is the placement wrong, and what other fan would you recommend? A lot of air flow, but for less noise, as with the other fans, hopefully it wouldn't need to ramp up as much.
Thank you!
Thank you!
I have the front one like yours plus two roof mounted exhaust fans as well as a fan mounted in the window. as for cpu cooler put an AIO on it and be done with it
