Temperature issues...
Permabanned
20 Nov 2011
Cambridge/Chicago
Hi, I have gigabayte Z68AP-D3 F6 motherboard... In Gigabayte touch bios utility temperature seems to be 10 degrees C lower than what core temp says...
So I dont know which one to believe :(... Once my temperature of CPU was as low as 16 degrees in bios utility, which made me doubt its accuracy...
Sometimes these CPU temp programs read the info wrong for whatever reason, or maybe the Gigabyte software has some offset.
I use Coretemp, realtemp or hwmonitor to check mine - maybe try all three!
with it showing 16 id tend to think its faulty, unless you have some serious watercooling in there, for example on stock coolers my cpu was idleing at 30 ish and on air with a gelid 20 ish. look at what its saying when you run prime 95 through it
