Temperature monitoring in NVidia drivers
28 Dec 2003
How do I view my basic GPU temperature from with in the latest NVidia drivers for Windows 7?
I remember being able to view the temperature in drivers of old but it's disappeared - have they removed it?
I remember having to download Ntune when i had a Nvidia card to get the temp through the drivers, used to say to download it when i selected the performance tab.
I use evga precision to overclock read temp and set fan speed
works well. or you could use riva tuner you can download them at
guruof3d.com
fan of rivatuner myself. I also set fan profiles so if I go into a game I just click and launch fan 100% :)
Yeah I know there are any number of other utilities that will do the job, just wanted to know whether the basic temp display that used to be in the NVidia drivers had gone.
They've moved all that stuff to nTune - which is an optional part of the drivers - personally I'd avoid it as its known to cause compatibility issues on certain setups.
