Temperature Monitoring Software.
20 May 2006
Hi guys.
I'm currently running on air, and i'm going to buy my watercooling kit tonight.
But before I fit it, I would like to check the temp's of;
RAM
GPU
Gfx Card RAM
Hard Disks
Anyone know any good programs that would tell me this info?
Cheers!
/NachT
depending on the GPU you may be able to monitor it via its own driver software (eg: gforce 6*** series upwards and some earlier models)
if you have a very good hard disk you MAY be able to check the temps of it via software, the rest, no chance really, you'll need a temp probe
Oh I found the GPU details :cool:
The Hard Disks i'm using are Raptors. Know any good software to check the temps?
nvm about the RAM pfft :P it'l live.
Speedfan will give your hard disk temps. And depending on your board it may give your GPU temps.
But I don't think there's any software that can read RAM and graphics card memory temps. I don't think they have any sensors.
