Temperature OK?
28 Apr 2009
I'm using a AMD 7850 BE and checking things out while running Street Fighter IV's benchmark system. Core Temp shows I'm at 40C when the CPU is used constant for over thirty minutes and I just wanna know if that's within a safe long term limit?
yeah, a good 20 degrees below what you need to worry about.
thats not really load though, try prime 95. if still well under 60, overclock it :)
