Temperature probes
8 Aug 2007
Guys,
Just a quick question, apologies if i'm asking the obvious.
I've just bought a Zalman MFC2 fan controller with temperature probes. Just wondering where you suggest that I place them.
There are four probes, but I already use speedfan and coretemp so can already monitor some of my system temps.
Thoughts?
I'd place them on the items the fans you are controlling are cooling, even if that means you double up. That way if you're in a game or something just glance at the panel to see what the temps are.
PK!
thks, will probably place on hdd, northbridge, southbridge and gpu
not sure whether it's worth putting a probe on the cpu as it's not going to be as accurate as core temp.
if placing on gpu, where should it go? I've got a 7900gtx- shall i just place on one ofthe heatpipes on the gpu?
thks
