Hi all
I have recently built a new PC using the i7 3930k processor (see sig for full spec).
I have a custom watercooling loop which runs as follows: Res -> pump -> Radiator 1( Alphacool Monsta 240mm (80mm thick) ) -> GPU1 -> GPU2 -> CPU -> Radiator 2 ( XSPC EX240 (35mm thick) ) -> Res. Both the radiators are using a pair of gentle typhoon AP-15's in a pull configuration. The Monsta is set up as intake and the EX240 is set as exhaust. I also have a 120mm fan in the front of the case as an intake and a 140mm fan on the rear as an exhaust.
The problem I have is that my CPU temperatures seem very high. (numbers that follow are based on stock settings). When I first mounted the block (XSPC Raystorm) I was getting idle temperatures in the low 40's and load temps in the high 70's to low 80's. Yesterday I remounted the block and re-applyed the thermal paste, now I have Idle temperatures ranging between 31 - 36 across the cores and load temperatures between 68 and 74.
Whilst this is a decent drop I still think this is too high, should I remount again? Can anyone who has a similar setup give me an idea of the sort of temps I should be seeing? When I overclock anything past 4ghz the load temperatures are skyrocketing to between 84 and 90 which is just ridiculous.
The ambient in my room is about 19c. Water temperature at idle is about 23c, the highest I have seen it after stressing the PC for a couple of hours is just over 30c. I have tried taking the side off my case to see if it made any difference to the temps but it didn't affect them at all, leading me to believe this is a problem with my block mounting and not case temperature. I used a reasonable pea sized blob in the middle of the CPU and tightened the screws of the block in an X pattern.
Is there a general consensus on best paste application method for LGA2011 processors? I would just like to know what I might be doing wrong as this is really irritating me.
Thermal paste is Gelid GC-Extreme btw. Sorry for the long post but I wanted to give as much info as possible.
Thanks in advance for any help given. Also could someone advise if I am allowed to post this in the watercooling section as well?
edit: I should have mentioned that any time i mentioned 'load temps' I was referring to temps produced by prime 95 using small ffts. I also tried OCCT but the temperatures were much the same between both
