O.K this is my setup
Case-- Coolermaster cosmos RC1000
PSU--- Coolermaster Real Power M1000
GPU--- Nvidia Geforce GTX 260
M/B--- Asus M4A79T Deluxe
CPU--- AMD Phemon llX4 955 BE @3.6GHZ @stock
Ram--- Corsair Dominator 4GB
Thermaltake 350cc reseevoir and temperature probe
CPU cooling--- Modded Corsair H50-1 120mm rad with push/pull config fans are 2x coolermaster 120x120x25mm 1200 rpm 17dBa mounted as intake at rear,240mm all copper rad (make unknow) 2x coolermaster 120x120x25mm 1200 rpm 17dBa mounted at top of case intake,bottom fan coolermaster 120x120x25 1200 rpm 17dBa exhaust.
my room temperature at the moment is 19.7c,the temperature probe is reading 20.2c and hardware monitor is reading 26.5c on all cores,dose this temperature different look about right?have posted screenshots of all setting,hope these help.FANIN0 is the H50-1 pump
