Temperature sensing?
12 Sep 2010
Durham
Hi everyone,
i was wondering if you could help me out a little. i was trying to find out how hot my system was running but unfortunately cant find anything to do with it. do my cpu/gpu etc. come with temp sensors as std or do you guys/girls fit them afterwords
Cheers
Joe
Most modern systems come with temp sensors built in.
Download HW monitor this show most temps on the system, I use this a lot.
Hi there,
If you are looking for accurate temperatures of your CPU and GPU, Coretemp and GPU-Z are what you need, they use the in-built temp sensors on the components.
HWMonitor also gives you loads of temp information on your components.
lovely cheers i'll download it when i get back (assuming its free) :eek:
i was thinking of buying a fan controller too, any idea if they come with there own sensors of do they somehow use the existing ones ?
thanks again :D
Prime 95 or Intel Burn Test to check for stability, both are free.
What SSD are you looking at getting, I'm running a OCZ vortex 2 60gb :)
the same one you have, im going to order it as oon as i find my wallet :D
Just downloaded HWMonitor and Prime95
HWMonitor is spot on and im not too sure what settings to run Prime95 on
Real Temp is by far the best for it.
http://www.techpowerup.com/realtemp/
i'll try that too
in the mean time heres a pic :D
picture.php
lol, ambient temperature 5C.
It gets lower than this, also I messed up with the CPU thermal sensor, only 2 lowly 800RPM fans are working right now because the others were hit by lightning. I'm waiting for 5 Gentle Typhoons 1850RPM. I will leave an update as soon as the fans arrive.
