Temperature / system monitor software
23 Jun 2005
Nottinghamshire
Hi All,
I have been having a look for the above and I wondered what you guys use?
I would like to be able to see the CPU and GPU temps and maybe even fan speeds from those two and the rest of the system fans. Main priority being the temps of the CPU and GPU though.
The motherboard I have is a Gigabyte Aorus Elite X570 and a Ryzon 3900x. I have looked on the motherboard website support section and, apologies if I am being blind, I couldn't spot anything there either.
Thanks in advance for your help.
MSI Afterburner is pretty nice at logging a ton of info.
HWinfo is also very good.
Thankyou very much, had a look at both but went with MSI afterburner. Than main display at the top of it shows the GPU temps and if I configure the graph at the bottom and take out all options aside from CPU temp (I can monitor the temp of all 24 cores if I wanted but dont feel the need) then it does exactly what I need.
Perfect and thanks again.
