Temperatures and voltages.
14 Jan 2011
East Yorkshire
Ok...I confess I know little or nothing about these things so, any advice on my new build would be welcomed to ensure everything is working ok.
I've checked the bios/cmos settings and done a health check with regard to temps and voltages which are as follows....
Vcore 1.456V
DDR 1.5v 1.584v
+3.3 ...3.392v
+12v .... 11.984v
System temperature ... 37-38 C
CPU Temp ..... 42-43 C
CPU fan is running around 3150 rpm average
System fans around 903
NB... around 1242.
In the section MB Inteligent Tweaker ( Gigabyte mobo), most things are I presume at default setting, which is mostly "Auto". I don't know enough about overclocking so, the settings are factory settings.
The CPU is a 955 at standard clock with standard cooler and has been running for a total of around 24 hours over the past few days.
Does everything look ok or do I need to make any adjustments?
Well my BIOS reports 1.385V for the Vcore, on a standard speed 955BE, everything is set to auto.
your temps are fine.
