That idle is hot, what the room temps like? my CPU in sig is at 23C on water (1.56Volts) in a room at 20C.Jihad said:I'm hitting about 59-62 degrees while playing Battlefield 2142 and idle'ing at around 48-51c![]()
Is that about right or should I be worrying? Got a AF7 pro cooling it and it's only at about 1.350 volts.
My rooms not that hot at all, I'd say pretty coldpegasus1 said:That idle is hot, what the room temps like? my CPU in sig is at 23C on water (1.56Volts) in a room at 20C.
Have you reseated the HSF or checked for a concave IHS.
Grr nah I haven't tried reseating the cooler, guess I'll give it a shot.markyb said:A little on the high side compaired to mine,
Im hitting 48c load - E6300 @ 3.3Ghz @ 1.45v and 31c idle with a Tuniq Tower.
Have you tried reseating the cooler? Does the heatsink feel warm/hot? Your idle temp indicates that the cooler is not making good contact with the processor.
That's quite high you know! Is that overclocked?JamesU2005 said:{snip}Idle: 65C
Load: 71C{snip}
JamesU2005 said:lol you should see my AMD 3500+
Idle: 65C
Load: 71C
Though I do have the heatsink fan on slow.
elfy said:O.o my ladies single core idles at 30
Lol my silent-air-cooled Venice 3800 is 30°C at full load (1.3vCore)elfy said:my ladies single core idles at 30
Hmm what chip, what cooler, what voltage, what overclock, what load temps?Jaffa_Cake said:My dual core doesn't go past 35 at idle even when the fans not plugged in
Big.Wayne said:Lol my silent-air-cooled Venice 3800 is 30°C at full load (1.3vCore)![]()
Big.Wayne said:Hmm what chip, what cooler, what voltage, what overclock, what load temps?![]()
although its currently sitting at 35 with the fan unplugged for 10 minutes.
Ah right, yeah I mean last night my fan actually came out of place and the temps shot up to 85 then it started to throttle, needless to say the fan is back on properly now.Atom said:I think the C2D is good for a lot more than that before it starts throttling.
Hear some good / some bad things about the AC7.
