Temporary Blackout Blinds
They look quite cool but some of the reviews are from people that got freebies, that being said - rainforest returns is amazing so if its not exactly to your liking you can easily send it back.
Yes I was a bit concerned about that...
In the end I ordered some theatre blackout material - and I will find a way to fix it myself - I think I could shut it in the door :)
meanwhile my photography pop up background works ok
If you want a good quality suction cup blackout blind have a look at the gro blind from the grow company we have a couple that we've used when are kids are little to help them sleep and they are pretty decent and the suction cups work and last. Definitely have a look on facebook ebay etc for second hand ones we got one that was completely unused for £8
