Hey Folks,
Just a quick question about tempratures.
The 4 cores on my i5 2500k are reporting back an idle temp of 35c (avg) 4.4Ghz Overclock with is nice and stable (eventually!!)
So, i thought how can i bring this down a bit. So i have done the following:
Made sure the cables do not obscure the flow of air around main components
Added 2nd fan to front of case - So now 2x fans sucking air in
CPU Cooler is a Noctua DH-14 with both fans pushing air towards the back of the case
Fan at the rear of the case sucking air out.
Room temp is about 22c
If i take the side of the case off, the Nocuta rad fins are cool the inside of the case is nice and cool etc.
Popped the Noctua off, cleaned and reapplied Noctua Thermal Paste on the CPU to make sure... Old paste had a good spread on the CPU and looked consistant.
So after all this my CPU cores still remain at 35c on idle. Woudl have thought it would have dropped by at least a couple of c.
CPU voltage is at 1.356 and idling core speed down to 1604mhz.
Cant think of what else i could do to improve CPU core temps? Ideas?
