Temps a bit high?
21 Jan 2010
Ceredigion
Hey guys,
Used ATI Overdrive to OC my HD6870, managed 960MHz on GPU Core Clock, and 1235MHz GPU Memory Clock.
Personally think that's a decent clock :p
However, the temperature now (so nowhere near load, haven't tried load yet as haven't had the chance) is 53 degrees according to GPU-Z (which uses the on-board die controller, iirc?). Is this too high?
Thanks,
Cookeh
That was odd. Loaded up CoD:WaW.
PLayed for 10 mins, (temps hit max of 59 degrees), yet the screen split into two and the LHS moved to the RHS of my monitor and vice versa.
Ideas?
