Temps are up..
Si.
Si.
22 Oct 2002
Melbourne, Aus
Hi all,
I've recently noticed that my CPu temp is starting to run a lot higher than it used to, I was normally approx 30degrees, but I', now averaging 36 which is kicking the fan speeds up creating more noise. Nothing has changed ont eh set up so I've no idea what could be causing it.. Any ideas?
I'm running an external Koolance watercooled system
Cyber-Mav said:
if your using arctic solver its probably dried up. thats why i never use AS since its not good for long term usage.
What do you use instead?
OP; sure your flowrate hasnt decreased?
CPU isn't overclocked at all.. and it's probably 18 months old. It was bought used so not sure what was used on the CPU.
Flowrate Looks OK, hut I havent really looked at it enough to notice if it's changed.
