Temps & Clock check
26 Aug 2005
I can see OcUK from here
Hi Everyone,
Had my real first go at overclocking my CPU, (E8400 CO), I'm starting at 3.6GHZ, below are the temps and volts etc can anyone offer advice if i could get more out. Think i'm right in saying the CO was not great for overclocking.
Much of the info is out of CPU-Z and real temp. The following was on prime for 30 mins (not a great deal of time i know, will go longer later), when i first started it would lock the pc up after about 2 mins so i up'd the vcore
Vcore 1.312 (drops to 1.29 once prime is at 100%)
Mem Vot 2.1
CPU 3.6GHZ (multi 9 / 1600mhz)
Peak Temp's (after 30 mins)
CPU 53.c
Core 0 58.c
core 1 56.c
Help & advice would be great,
Many thanks
Bit of an update on the above,
ran Intel burn test (20 runs) passed fine, temps got much higher than prime, just running prime now at 30mins again looking good,
Only thing i looked to take it to 3.8ghz, but the pc fails to post any ideas on what i need to do i.e is it more vcore time??
many thanks
Peak temps of 53 are nice, I get 49 so I am about par with you.
vCore won't heat up too much at 1.3 so that could be why your having low temps :D
Cool,
Good to know i'm on the right track with temps, still trying to work out whats wrong with the 3.8 failing to post, but will keep an update going, also over 1hr30mins now prime and still going well.
nice one
Cool,
nice one
If prime is still going after 5 hours you can stop it. 5 hours is basically the threshold for faults.
Ok,
Sounds good can try some Crysis and other game benchmarks to see how my comp does now, wicked.
