Hi Guys,
Didn't know which forum to stick this in as not sure if it's a OC question or watercool question
Recently upgraded my rig to a 4770k, Z87X-OC, Teamgroup LV 8GB.
I'm running the following watercool setup: XSPC Raystorm CPU Block, EX360 Rad, Dualbay pump/res, XSPC Raystorm GPU block for a 770gtx
I've tinkered with an overclock however temps are seriously holding me back, it wasn't something I was expecting as my system was watercooled. Anyway, here are the numbers:
Stock:
Bios Temp: 34 C
Idle Temp: 31 C
IBT Temp: 81 C
System Temp: 36 C
Overlocked @ 4.5Ghz:
Bios Temp: 40 C
Idle Temp: 35-40 C
IBT Temps: 97 C
System Temp: 36 C
VCore: 1.280V
I've tried reseating my CPU block, re applied paste but still runs the same, is this normal? Serously considering buying the EK "naked Ivy" kit and delidding (scared me a bit though).
Any advice would be welcome on this as I kinda wished I had saved a bit more and got IVY-E or waited out for next gen!
Stock:
Bios Temp: 34 C
Idle Temp: 31 C
IBT Temp: 81 C
System Temp: 36 C
Bios Temp: 40 C
Idle Temp: 35-40 C
IBT Temps: 97 C
System Temp: 36 C
VCore: 1.280V
